Need Help Y Overcurrent on JV33
eesanopi
Hi,
I start to have this issue two days ago in my JV33, at booting printer sends error 43 and stops operation, if cart is outside of cleaning station it can't find home and crashes in bot directions sending the error 43 again, I checked enconder strip, encoder sensor, homming sensor, rail lubication, all is ok, do you have any idea?, here is a video.
Video 1 | Signs101.com: Largest Forum for Signmaking Professionals
Thanks in adavence of your help
Best regards
Maybe the Y origin sensor is not reading properly? It should be able to find the home position if the Y origin sensor is working properly.
JV33
Hi,
Best regards
Hello, can you tell me how you solved this problem? My machine started doing the same thing yesterday...
D.J.
I am having the same problem.
new Y motor, both pullys, encoder strip and sensor. Y sensor is working properly.
please advise how you fixed your problem soo I can fix my problem.
