captainron19
First time I had this happen.   Yesterday put some striping on a pickup truck. Did a 3" stripe basically around the entire perimeter of truck.   Used 3M reflective scotchlite with a dry application of course.   Installed the vinyl indoors which was a firehouse and it was a bit warm in there.   Installation went fine and looked great when I left.   Had one two small air bubbles not worth popping that I told them they would work out over time.
Today I got a call that the vinyl was completely bubbling up. Of course I went right over to location. It wasn't as bad as feared. But...There were a lot of air bubbles that appeared but the vinyl was all intact in still in place just fine. They informed me they moved the truck outside last night and left it out today. It is pretty warm (almost 90 and it was sitting in the sun).
Should I be concerned or will these bubbles most likely work their way out? Probably 95% of them are so small and numerous I wouldn't even consider popping them out. I know reflective material breathes less and it may take longer but just looking for any input as this is the first time I ever saw this happen.
