Favorite Wall Mural Material?
CS-SignSupply-TT
Fire rating?
It actually printed great! I used the sample you sent us to cover a pillar in our showroom. However it doesnt seem to stick down completely. Should I apply heat and a roller to it maybe? The only other downside I have is that The company now needs the mural material to be fire rated. Koro Graphics is the only material I can seem to find that is fire rated. Any others that might be?
Scotty, I am tracking down the fire rating information for you. I am forwarding your concerns in this post to the product manager for clarification.
Letterbox Mike
Only complaint would be the translucency of the material. Overlapping panels show increased saturation/darkness.
After you apply the material, go back and cut the seams through both layers of material, and then strip the under/overlaying excess out so you're left with a butt joint. Phototex won't shrink and pull back at seams so when you do this the seams completely disappear.
klingsdesigns
I use sera mark and like it. I am only on my first roll so not sure about the quality issue stated above about roll to roll. But it cuts nice and sticks very well.
