Help!
mrk.Cram
I have run into a issue that has been a costly issue for us a few times... When using the Dimension tool, I have noticed that when you change the size of an object(by mistake) the dimensions still read the same measurement. Unlike Corel, which is real-time and will change with the size of the object. This has caused a few signs to be cut the wrong size. Is there a way to change this or am I stuck with checking every sign, every-time.:banghead: I hope this makes sense. Thanks!
