Illustrator not opening
Neyland
Hey everyone, Has anyone ever had this issue? I am getting an error message when trying to open Ilustrator cc on Mac. It says "Not enough memory to open the illustration". I have plenty of memory on the computer, and have restarted a number of times. Nothing has worked. Anyone????
GAC05
Quit buggin' me
I've seen this on a win7 with CS5.
The error pops up and the AI window shows up in the upper left hand corner minimized down so that just some of the tool bars are showing and no workspace.
Once I restore the window to full screen it will close and reopen fine the next time around.
Seemed like it was happening to me when I was switching the desktop between 1 and 2 monitors.
Worst case you could try a reset to default:
Cmd+Option+Shift on launch (I think).
wayne k
guam usa
Neyland
Thanks guys. I've tried all of the above suggestions, and it's still not working. Not sure what to do. Thanks anyway.
qmr55
If you try and open illustrator first (not by doubleclicking an .ai file, but by actually opening via the illustrator icon) and then open the file via the File > open menu, does it work?
klmiller611
Another idea to try is to open it in Acrobat, it will run through Distiller, and save it back as full PDF or EPS, and Illustrator might open that. Of course, save it as a different name to avoid damage to your original file.
Ken Miller
