pdf file is corrupt?
GVP
Yes, this is likely. Try opening in Acrobat Reader first - at least you'll see if the file is ok.
beermonster
place in indy and re-fry the pdf out
or open in acrobat a take a peek
opening in illy (do NOT let the "adobe" police hear you're doing this) is ok if fonts are outlined - you might get errors and font issues if not - file size may be fun too
i agree the pdf may be a 1.7 or pdfx4 - probably newer than corel can handle (i've never used corel )
Morph1
Print all
Well believe it or not but sometimes it works when in import mode you actually select the pdf import filter and then hit import oppose to using the all files import selection., personally I hate PDF the colors are always off and printing actual colors as whats seen on the screen is always different.
I wish JPG had a multipage format, I would never look back at pdf junk.
