Need Help Roland RF-640
Witer
Hello,
Just need your expertise...
When i print 100% of each cmyk bands i have got vertical banding on black and cyjan. Magenta and yellow is ok.
Of course every color which is dark has banding. Machine is new, month old. Service tech do not have clue and postponing visit to solve this problem.
What can cause such phenomenon...
Thanks and regards
Kris
Joseph44708
I Drink And I Know Things
Print heads are garbage.
Happened to me, I replaced in my xr640 and within two days I was getting banding.
Got another set of new heads and printing great.
edcooleyar
My understanding is vertical banding is perpendicular to the movement of the printhead. Usually not caused by faulty heads which band the same direction the printheads move.
Witer
Well,
What type of ink, paper and rip are you using?
Thanks,
I appreciate your reply...
Regarding paper, I was using Satin paper WJET SATIN 200g/m2.
RIP: VersaWorks,
Ink: Bordeaux fuze nr4p...
Doesn't matter which profile I used, which temperature, still have this banding which is perpendicular to the movement of the printhead.
Service tech was advised to change feed adjustment which limit this banding. But I received too long prints...
For me strange is that I see banding only with black and cyan. Issue is not visible with magenta and yellow.
edcooleyar
Try turning the vacuum as low as possible. Raise the platen gap and add a pass delay if possible. Looks more like a pump or head flow problem than vacuum or cockling.
Witer
Well, today I made default calibration of feeding with my paper. The strange was that default vale was +0.3% in the service menu.
I used different media paper and foil and with 6 pass I have this vertical bands. But with 8 pass it is significantly reduced however it is still present.
In my opinion there can be ink flow issue or head is faulty, because issue is happened only with cyan and black color. Magenta and yellow is ok. The lighter and darker bands are in the same place on cyan and black.
How I can check if it can be link to head or to ink flow...
thanks a lot for your support
Witer
Additionally I wanted to point out how the feeding adjutments looks on this paper.
There is no clear enough clearance between columns. please see below photos:
Additionally when I check this via magnifier there is strange situation as few begining dots are smaller comparing to the others. On the foil dots are the same...
For each print I have different gap between columns... how it possible...
BR
Kris
Nino Graphics
Hi, did you fixed the problem?
I bought a new rf-640, and it has never printed without banding problems, also the prints are inconsistent somehow.
I think varranty is the only way to fix the this.
Br, Nino
