Second Update for Omega 5.0 ????
D
derfrankfurter
Guest
Hello,
For what the second update is actually meant?
I do not see any particular benefit.
I also have some problems characterized with the option
"show smooth drawing"
If I press F8 is the object of focus like a bad JPG!
In the registry I put "smooth draw" to "0", but it comes after a restart again and again.
It sucks!!
Fred Weiss
Omega updates are usually bug fixes. Not sure of the benefits of each but they cause no harm ... so why not update?
I've never even used the Smooth Drawing feature, so I can't help you there.
D
derfrankfurter
Guest
OK, I install again.
Thanks for your Message.
Fred Weiss
You are talking about the automated update that you perform from the Help menu in Composer aren't you? If you are talking about installing again from a CD, then that is not what I understood. Once Omega 5 is installed, all updates should be done over the internet using the "Check for Updates" command located in the Help Menu of Composer.
