Show Smooth Drawing: How to disable
hydo1
I am running Omega Composer 5.0.0.1369. They have turned on "Show Smooth Drawing" by default and I'm getting tired of unselecting it every single time. It makes everything on the screen look awful and when I generate a PDF proof they are like 60 megs and look horrible. Any ideas on how to set it so it doesn't turn on every single time I start a new job?
hydo1
Thank you! I actually unchecked that half a dozen times and it never worked before. I think I was hitting "Save All Pages" thinking it would do the trick, guess not.
D
derfrankfurter
Guest
Smooth Drawing
It is better you go to the registry.
There you can disable it permanently.
I see right after point below which it stands.
D
derfrankfurter
Guest
SmoothDraw
Hello,
start Registry>Hkey_Current_user>Software>Gerber Scientific Products>composer>View Settings>Smooth Draw
set "0"
Start Composer new !
