10x20ft sign
HulkSmash
Hey everyone. Thanks in advanced for the help and suggestions. I've done many signs this size, but i'm looking for a more practical way to do a sign this big. This customer wants a sign 10x20, and biggest sub straight i use or can even find is 5x10. This will be on thick di bond mounted to a brick facade. I really dont want to do this sign using 4 pieces and then puzzling them together at the install.
Thanks again.
petesign
That's the biggest substrate I have found as well. Do you have a way to transport a sign thats bigger than 5x10' sections?
Pat Whatley
Another idea....but not as good as Dibond with 1x1 frame behind it.....
2" x 2" square steel tubing frame with an 18oz. banner stretched over it.
Build a frame first, instal that on the wall and then mount your 4 pieces of 5' x 10'.
Easy/peasy.
Craig Sjoquist
5x10 really the only way and be able to transport with least amount of pieces to put together and be able to handle.
unless you have a crane a 24 ft low trailer build a rack to hold ... do you have a 50 of these even 20 other that not worth the effort.
TheSellOut
Easy/peasy.
That's really the only, and best, way to do it!
I would use 1" aluminum tubing for your frame work and you could always frame it in with some 1¼" aluminum angle!
Mosh
Tubing frame, VHB tape, how high is it. I bet if t is 10' up you will not even see the joints. We do big stuff in sections all the time.
iSign
I think astro8 or Fitch showed off an awesome one piece 'roll lexan' job he did a while back... not sure if 10' roll exist, but the 20' length is no problem.. I'll look form the link!
Mosh
Build a tubing frame and use .080 aluminum sheets and weld the seams closed. sand and prep like you would body work on a car. Me thinks this would be over-kill.
