Click to Support Signs101 ...
Did you change all That because of no Ink? If so the print head is shot. Manually purge the head check the curtain but it’s likely cured. What kind of printer is it?
Had to replace manifold due to one of the nipples broke off as I was changing dampers, other than that, it was a basic age/time proactive swap to ensure continued operation.
