2 cutters on Winplot
HrvojeKucic
Hi, I use Winplot, and have 2 vinyl cutters (S2 and S3). Both are installed in Winplot, one is connected to USB, the other via Ethernet. Is it possible to send a job to one cutter, and another job to another cutter? When I start Winplot and send first job, menu to choose cutter appears, but after selecting one of cutters, that menu no longer appears, and all jobs go to the originally selected cutter. Confused... :( Thank You in advance.
FrankW
Check the „Output“-Menu in Winplot. There you should have an option to switch between the cutters.
netsol
i would guess there is a second license or an upgrade needed to drive 2 cutters at the same time
