4k Monitor and UI being too small
Inu
Has anyone tried to work with Flexi on a 4k monitor. The User Interface is not scalable and everything is too small.
I am aware of the DPI adjustments you can make in Windows to counter this, however that completely defeats the purpose of doing graphic work on an extra sharp monitor.
Is Flexi just way behind the times? I've been using Flexi for 18 years. Their lack of tech adaptation is something I'm well aware of, but this seems like a huge oversight.
Has anyone found a different solution?
Have you tried using the scale settings in the Windows display settings? It doesn't change the resolution but changes the scale of the a lot of UI features and fonts etc.
weyandsign
If you've been using Flexi for 18 years then you already know the answer to the question of being behind on the times. Other than different icons, the Windows 98 version is the same as what you're using now.
Vassago
The windows scale only affects the ui.. I use loads of programs with the same issues.
Only a few of the older programs won't play nice.
