ledbe
The Individually Addressable Programmable COB LED Strips, the width only 4mm and work on DC5V,
160PCS LED Chips and WS2812 ICs control each piece of LED Chip to achieve hundreds of amazing lighting effects.
you can cut to any length from the cutting point for your project, the back with double-sided adhesive tape,
easy to install for indoor lighting projects, you can use them in your cars, under-cabinet, closets, ambient lighting for DIY projects, etc.
Link: https://www.ledbe.com/4mm-dc5v-ws2812-cob-programming-led-strip-lights
