6mm Brushed Aluminum Composite
Pinfinity
Can anyone help with locating 1/4" or 6mm brushed aluminum composite? I need a 4x 8 sheet but needs to be at least 1/4" thick. I only see 4mm availability.
Its for exterior use.
Thanks much
T
Tropics09
Guest
To add to that, one of our big name customers is requesting 18x24 building signs out of brushed aluminum composite. Ive noticed that our slitter leaves a ridge on each side where it cuts. Any advice on how to decrease/eliminate this?
FYI- We have a Fletcher Substrate Cutter.
Also keep in mind that a new substrate cutter is not an option, and we do know that we can have the brushed aluminum composite pre-cut from our distributor, but we would like to maximize profits.
Zendavor Signs
Mmmmm....signs
I know this is an old thread....but brushed finish Alupanel is NOT for exterior use, nor any aluminum composite material that I know of.
See note at bottom here:
http://www.multipaneluk.com/products/sign-materials/alupanel/
Where can outdoor durable brushed aluminum sheets be purchased? Gemini sells it, but larger sheets are crazy expensive. We have purchased the .040 thick sheets before, but that it a pain to mount to some kind of backing.
synergy_jim
we use brushed outside all the time. along with a disclaimer that it may corrode.
CanuckSigns
Alupanel brand has a 6mm brushed aluminum/mill finish sheet available, it is available from Grimco up here in Canada, not sure about local suppliers
While it is not waranteed for outdoor use, we use it quite a bit with no issues, the other brushed finishes will fade in no time outdoors, but the regular brushed aluminum seems to be fine.
