A file with the same name exists??
John L
In Flexi 8, whenever I send a job to cut manager, I get a seperate window that pops up and says "A file with the same name exists". I have to click to accept at that window and then it starts plotting. How do I stop it from doing this?
John L
Never mind... I changed the plotter settings to "after output -- delete". Mine had been set on "after output -- archive". I don't recall ever changing that and it just started doing this a few days ago. Is there some reason I shouldn't want it to delete after output?
player
If you want to reprint it you have to rip it again. IF you use "hold" it will keep the file for a reprint.
P
