Access to and HP Latex Printer for network issues
guillermo
Hello to all
I have an HP later printer that is been working fine, but....... this Monday I came and was not able to print to it, no network connection, issue is that the IP address the printer is using was input manually, however, DHCP was not selected at that time, now the same IP address on the printer is being used by a PC, because of this I can not print.
Does anyone know the user name and password for this printer and is willing to share?, I believe is a standard name and password, tried Admin and 0000 as password, but did not work.
dypinc
If you have a router reserve that address along with other important machines. That way you avoid having the router reassign addresses of your existing machines.
ikarasu
Why not just manually change the IP on the computer.... Reboot the printer and it should grab the old IP.
Otherwise you'll have to change your Rips settings as well on the printer
