PMG
Ive ran into a problem with this font and contour cuts ....and it only happens with this font and i cant figure out why.......when i use this font in flexi and i put a outline around it then do a negative contour cut on it,the cuts are off on the x and y axis by and this is no s**t a 1/4 inch or less sometimes.my cutter is spot on with any other cut i make,,just with this font .....anybody ever run into this type of problem? i have a job for a customer that requires the font at least once a week...and i need to pin point this problem.
