Acrylic light box
nolanola
Hello forum.
I'm looking for some guidance on how to make an acrylic lightbox sign 18" x 12" x 4".
We are going to laser the 6 pieces and glued them together. The LEDs will be placed on the 4" side (the edge) facing inside.
What glue should we use? What should pay attention to?
Thank you.
JBurton
Signtologist
Weld0n 3 and WeldOn 16. I don't know how you will not have multiple hot spots from your description of building it ??
I would have agreed, but I just pushed this one out the door and it looks great. Ended up doubling the modules because we received extra and the power supply was woefully underloaded.
Make sure you have a white coating inside the cabinet. Indirect lighting like these have a tendency to reflect the paint color and 'contaminate' the white light. We painted the referenced cabinet purple, and had to skin the inside with white to keep it from glowing purple on the opposite side.
  • Purple Cow Directional 4 inch.pdf
JBurton
Signtologist
Oh wait, you want the returns to glow as well? Oldschool simplest way would have been to get some neon fabbed, mount it freestanding vertically, and use the lightbox as a 'cover'. That or a U lamp. It's going to be pretty hard with LED's though...
Johnny Best
Weldon 3 should be good enough for keeping acrylic together at the seams. Just do not spill it on the faces, use the needle tip to get into seams, is it clear acrlic or the frosted white as you show, glue sets up quickly. VHB tape for LED on the sides
nolanola
Thank you!
The edges don't need to be illuminated.
The plan now is to use COB LED tape on the edges and block the light on the edges with black vinyl on the inside.
Bradley D
www.jigsign.com
I think you would get better illumination if you added a baffle in the middle and make it 6 inches deep. The baffle could be made out of Lexan and would provide a safer surface to mount your LEDs illuminating both directions. Let us know if your method works. It might just be small enough to get even illumination.
nolanola
Made some progress, looks good so far.
I'm thinkin about a way to suspend a ring made of led's in the center of the box. Maybe zipties from all for corners.
JBurton
Signtologist
Only problem with zipties in the corners, aside from the jank factor, you'll end up with dark spots where you mount the zip tie to the box. Why not cut an additional piece of acrylic and stick the leds there?
