gabagoo
I have a Fletcher 3000 but it is very hard to cut digital prints with it once they are applied to coro or pvc because, everything has to line up 90 degrees to the cut line. It can be hard to manipulate 4 x8's to try and move them 1/4" due to material out of square or print not put down 100% square.
In any case I have seen those cutters that can sit on a table and you just pull the blade assembly across from one side to the other.
I have been using a straight edge and a heavy duty Olfa cutter but anything past 36" and I have a hard time reaching across.
any recomendations?
any recomendations?
