Anyone have the Encryption Code for Hosonsoft DTF software?
chrisphilipps
The encryption code is tied to the board in the printer. There isn't a generic one that works for all of them. You will have to work with the tech to get the correct one for your unit.
chrisphilipps
I forgot the mention that there is normally an option to "apply for a temporary code" in the software. It doesn't actually apply for anything but it does allow the software to run for 3 days without the code. This option is only available for use 1 time per board.
It should be located in the Encryption Menu where you tried to put the Encryption Code in.
