Application Fluids? What are they?
Ken
Ok..I didn't read the whole thread..What I liked about this Conook..is that you turned away some work that you were not comfortable with...that is very smart.
So..I use Rapid Tac for bubble-free results..workd well,,,takes a little extra time and minor expense..but gives great bubble-free results...
Cheers!
Ken
iSign
In a one gallon jug, Combine 1 5th if bourbon, 1/2 teaspoon of baby soap and water to make one gallon of solution.
Since the developement of the Big Squeegee, I leave out the soap and water.:toasting:
and if you don't have a cig squeegee... get one... but until then, if you use soap & water... just DON'T mix it with the 5th of bourbon!! :toasting:
andy
Your kidding right. Most window cleaners have ammonia in them that kill the glue. Read the label.
On another note what a refreshing newbie we have that actually wants to learn something. Welcome aboard Conook!
:Welcome:
Hardly. The active non streak ingredient in most glass cleaner is just vinegar.
I've flood coated hundreds of square metres of window etch using 99p glass cleaner as the lubricant- no adhesive eating, no difference between "special" fluids and 99p windex.
