Automotive Clear Finish over Wrap
daenterpri
Is it ok to put a clear finish over a vinyl wrap? A customer wants me to wrap a steel water slide, and then he wants to spray a clear automotive finish over it to keep it sealed and protected. Is that ok? Any particular finish better than another?
Thanks for your help!
rjssigns
Perfectly fine to clear coat a laminated graphic. Valspar AC4400 clear is super tough. It's what I use on motorcycles. YMMV
2B
yup perfectly fine, we have done a fair amount of restaurant's bars and table tops with vinyl then seal it with clear resin
daenterpri
Thanks guys! Now, in this scenario, I figured out that adhesion would be best using a calendared high-tac vinyl. Since calendared media can shrink, especially outdoors, what would happen if we put a clear finish over it? Would the clear finish protect the calendared vinyl from shrinkage?
Thanks again!
visual800
Thanks again!
depends on how deep you bury it. I have signs out there for several years that look great, i have had some vinyl curling upmundef the clear on others, i have even had the clear scale off the vinyl. And all were done the same way. You just never know.
make sure you scuff the vinyl and clean properly. We prefer to clear non laminated vinyls as we did have the clear pull the laminate off the clear ona. Large sign.
i dont like laminate for the reason it is so strong when it contracts it takes everything with it
player
I thought cast was better because it shrinks less. If you use a calendared vinyl and it shrinks under the clear, that could be a problem.
When clear coating it is good to lay a very light coat, let it dry, and repeat a few times. This sets up a protective barrier so the thinners and clear chemicals don't attack your vinyl.
