Back lit frame...lightbox?
Tony Rome
I am looking to either make or buy a frame for the purpose of displaying a translucent print on coroplast/glass/acrylic for a buddy of mine.
I am looking to make/buy it for no more than $15-$25 looking for around 18x24 or 24x36.
I found snap frames in that price but they have no depth, nowhere to put LED lights.
I want to put my own led lights behind it to light it so it has to have at least one inch depth...the more I type the more I am thinking I am going to have to make this.
But, you never know does this exist?
If I make it I would probably use wood and basically just make sort of a picture frame/shadow box and use acrylic with a translucent vinyl print.
Light boxes are hundreds of dollars so that will not work, is there anything out there I can look into?
Thanks!
J Hill Designs
w/o special low profile LED's I think minimum you should go is 3.5" deep
I DON't think you can even get materials (from a metal supply house) to build it for $15
Tony Rome
OK thanks, I didn't know about the depth issue. I assume at this point I will have to get the raw materials and make it myself. But I will keep checking back here. Thank you.
J Hill Designs
backer: .063 aluminum/dibond - white
sides: 4.5" - 6" wide length(s) of .040 with a break @ 1" (for an 18x24 you would need a 7'1" section (the extra 1" is to overlap the seam where they meet together) and a 90degree notcher for the corners
face: acrylic with trimcap
Tony Rome
Wow, thanks, so how would the backer Connect to frame, how would acrylic?
J Hill Designs
yes, as said by zsigns, the acrylic would get trimcap, then screwed to the sidewalls of the box
the backer can be riveted on - that's what the 1" break on the sides is for
tomorrow I can draw up an example if needed
Tony Rome
well I am pretty sure I get it, but hey if you really want to draw something up I sure wouldn't turn it down, unless you were being sarcastic, then it was mean but funny, lol.
Now to actually bend the metal is there an actual specific tool?
Thanks.
