Instead of applying vinyl graphics to a cabinet face has anyone back printed using UV inks on clear acrylic with a solid white printed over it? How does it look when illuminated?
Thanks,
Mark
Thanks. Yes I am back lighting, I would have printed color/color/white. The sign I am working on has a peachy color background and I hope it doesn't look washed out.If you're doing backlit signage, you want to print 3 layers of ink - color/white/color. It's the same idea as the reverse print on the inside of a backlit solvent printed sign - it prevents the colors from washing out when the sign is lit up.
If you're not backlighting it, though, a 2 layer print (color/white) is fine, and the colors appear nearly the same as printing on a white substrate such as vinyl.
