bending pvc
Cynosure
I'm wondering if anyone has a recommendation on bending 3mil pvc for hanging on a wire. The customers sample is 14" tall with a 2" lip, about 21" in length. If it was one, i would heat gun it. I need to do 100, and i'm sure there has to be a product out there to help things go quick and remain consistent. Thank you in advance for any suggestions.
WB
You can buy heaters made just for this all you need to do it setup a jig some you can bend 100 exactly the same.
Sign Works
You can buy the heating strips from Tap Plastics. Intended use is for acrylic but Im sure it would work with PVC as well.
phototec
Plastic sheet bender
Here is a video showing nice DIY plastic sheet bender and although it is being made for Acrylic plastic I have used mine for PVC plastic sheeting.
If you don't want to use the Nichrome wire and transformer, use can purchase a standard plastic heat cable from Amazon:
http://www.amazon.com/Craftics-24-Plastic-Strip-Heater/dp/B003GUPFPG
[video=youtube;wVEf7PfuKxo]https://www.youtube.com/watch?v=wVEf7PfuKxo[/video]
kheebl
Member
I am going to build one of these. I have hundreds of feet of the nichrome wire at home that I use for making coils for my e cigs. Now I have another use for the wire.
phototec
Hey how about putting 4' in an envelope and sending it to me?
Thanks :thumb:
kheebl
Member
I would need to test how much wire is needed. I think I will have to double it up the thickest I have currently is 28awg. Also have 30awg and 32awg.
