bitmap tool question
fisheye48
i have an image that i am trying to put a contour cut on. but when i use the bitmap magic wand to make it transparent it only gets half the oval and not the other half...any ideas on how to get the whole oval to get a contour cut?
J Hill Designs
Im guessing the image is cropped so that the border of the oval hits the edge of the bitmap - needs more space around it
bob
Use the shift key and select the other half with the same magic wand. Or enable "Select Similar" if the background color does not appear in the part of the bitmap you want to keep.
fisheye48
THANK YOU SOOOO MUCH BOB!!!:U Rock::U Rock::U Rock::U Rock::U Rock:
