blue printing prob.
evie
I have used every color profile possible, and still can't figure this out. Everything prints fine on my outdoor falcon. I am using flexi 8. When I print blue spot colors, it comes out purple. If I change the color values, it prints the same purple. All of my lines are open, test print prints fine. If I change my profile to no color correction, it will print blue fine, just not the blue that I need (it's too dark).
mikey-Oh
there's an option for spot colors in the production manager before the rip... might try toggling the check box
evie
I don't have to do this with any other color, is this something that I should always expect with printing blue spot?
mikey-Oh
hard to say, just attempting some problem solving.
have you tired converted the spot color to cmyk or rgb and knocking the red/magenta a bit?
another step, probably what you should do first, print out a swatch guide, that way you know what colors you can get and find something close to the true swatch
evie
The blue prints fine on a swatch, but in the actual print files it is always purple when I use a color profile. It is more than one file doing this, so I know it isn't just this graphic.
mikey-Oh
crazy, so if you print the spot by itself, it's perfect. when it's in the whole eps, pdf, psd, tiff, etc... only then it misprints? and all the other colors are fine?
