Bought a mutoh designjet 62, need help please
PROBIRD
Purchased this yesterday and it came with a white lpt box thing that connects to 110 volts and connects to router with a ethernet cable.
How do i get this all communicating together?
Does the printer have its own i.p. address? If so how do i find it?
Flexi is asking for an ip address and i do not know if its wanting the printer or computer or router address.
Any help would be appreciated.
Thanks in advance.
When buying such a piece of equipment, usually one gets a day or two of training and the techs will generally set everything up for you. You should call the company that sold this to you and insist on some on-site training.
AUTO-FX
Most people use a server box. And what is it again that you bought? A Mutoh or an HP?
Cibersupply can help you. He is a merchant member here.
PROBIRD
Bought it used from a sign shop, not an actual printer caompany.
It is a mutoh sdmp-62j model number, says prismjet extra on front.
Ha, i put designjet, what an idiot. sorry bout that.
I hooked it up with an lpt cable and it works, just messing with flexi and evry time i print something it makes wider and shorter than what shows on the screen.
randya
That sound like a RIP driver issue, or a resolution issue.
You should be using a Falcon Outdoor driver, which is different from a Falcon II.
