Bouncing Blade!
midnightmadman
Hi all. Im just trying to figure out why and how to fix my bouncing blade when cutting with the Q100
It seem to happen more on horizontal or angle cuts.
Thanks!
gabagoo
I have an old graphtec that used to do that and I would have to put white grease into the bearings in the blade holder to free it up. My newer Graphtec blade holders seem not to do that but I am not sure you can even access the bearings inside anymore. Take a look and see if it is possible
Pat Whatley
Gaboo is right. The blade isn't turning completely. When it tries to cut it's pulling the vinyl into little peaks that make it hop. A drop of machine oil in the holder should fix it.
