BIG EASY DOES IT
We have a HP L25500 Printer. We have had it for about a year. About a month ago we started having issues with it bowing the print. We downloaded the new software which contains a menu for "Substrate Straightness Optimization". Now our issue is with consistency. Today for example... I loaded a 54" roll of 3M IJ35C-10. I printed a 50" ruler With lines above and below it. The line had a bow in it (even though last week we had it correct). Anyways, I adjust for the bow and print another ruler. This time the ruler comes out perfectly correct. YAYYYYYY... But NO. Then I proceed to print some small ribbons for Print and Cut. The quality of the print is good but there is a bow in the print. This time the bow is the opposite direction.. Same Media I never unloaded it. Same Profile settings. What the hell is going on. I know one guy on here operates 4 of these same machines. Do you have any of the same issues. HP says lower the curing temp. and raise the number of passes. Which we have tried a little bit. It doesn't work. Then HP tells me it's the material... I have been using the same material for 8 months with no problem and now Your telling me it's the material PLEASE HELP. Guess I should pour this> over it and light the whole thing on fire.
