Buying a used Soljet IIV 54"
Highley
Any info on this printer would be a great help as if I should purchase it.
Any major problems w/buying used? Anything I should look out for ETC...ETC...ETC...
Thanx,
Shane
T
TonyC
Guest
Testing
The first thing I would do is a test print. The second thing would be to ask if the owner has been using Roland ink.
Maybe take a file with you that has good color variations and maybe some metallic background. Also make it do a contour cut after unloading the print. See if it finds the crop marks and cuts correctly.
Other than that you can have a professional look at it.
premiercolour
you can see how many hours have the printer printed from the service menu. Usually, the Roland owners should know how to get one. Nozzle check, print fill ink, print graphics, find a technician to go with you. Repairing these machine isn't fun(cheap). To pay that technician $100 just to go through the printer is worth every bit of your $100 buck.
