Barry Davis
I have owned this Roland CAMM-1 since the mid 80's. We only use it for cutting tiny lettering, so it probably only has about 40 hours on it total. I have never had a problem...until now. About 4 times out of 5, I get an error message "Illegal Pinchroll Position".
It looks like the sensor is on the top/back of the blade holder assembly and the metal blade mounted on the pinchroller passes thru the sensor.
On startup of the plotter, the blade holder only goes to the left about 2 inches and stops, giving the error message. I cannot figure out how the plotter thinks the pinchroller is in the wrong position, as it never goes over to let the sensor see the roller. For a while I could turn the plotter off and slide the blade holder over to the left, then turn it on. That way the sensor passed over the pinchroller and "saw" its position. This seemed to work for a while, but now it works only when it wants to.
Help anyone?
ps: called Roland and the only thing that they knew for sure, was that they did not have any parts for that plotter.
Help anyone?
