MatthewTimothy
Found it on another forum that they have listed as Mutoh Valuejet 1604 A. Cant seem to find any good documentation or information about it. Let me know what you think of this printer.
Just the normal things that you would look for on any used printer. Have a good look at the nozzle check, make sure the pump is working and print out the error log to see if the printer is having any error messages that are repeating.
so i should make sure it actually works, lol
i have 2 hp 9000's for sale in the classifieds
Be penny wise!!! Research and test until you are confident of what you are about to invest in. By the way, is this your first venture into wide format digital printing?
The main difference between the 1604 and 1614 was the placement of the ink cartridges. The 1604 holds its ink carts horizontally. With the 1614 Mutoh moved the slots for the carts to the top of the printer so 440ml carts could be held with less of a chance that the weight of the cart would weaken the seal to the ink lines.
There's not a major disadvantage to the original design but you'll probably have better success with it using 220ml instead of 440ml carts.
As Tim has advised, be wary. Used equipment may have been left idle for months causing clogged heads and lines requiring significant investment to bring it up to speed.
