Canon Arizona 1380 XT Light colors remove
rom3o
Hello, I have an Arizona 1380 XT printer that has LM and LC colors. I know I can print without them using profiles from 1360 XT but I need to completely remove them from the machine. Is this possible? Canon service says that there is no such possibility but I do not trust them.
rom3o
Canon should be able to change the inks to cyan and magenta for the CM2 config.
thanks for the reply. in my arizona there is already Cyan and Magenta. I would like to completely remove Light cyan and Light magenta
Pauly
Printrade.com.au
yes, but the 1380xt has 2 configs
light cyan & light magenta
OR
CM2 which has 2x cyan and 2x magenta channels
otherwise you're downgrading the printer to a 1360xt and there's no point to that.
rom3o
OR
yes, I want to downgrade my printer to 1360 XT
I already print on profiles from 1360 XT
Pauly
Printrade.com.au
This makes absolute no sense.
You already have 8 channels...
Like i said, the 1380 has 2 configurations
C,M,Y,K,lc,Lm
OR
C,C,M,M,Y,K
+White & White/Varnish
All you need to do is get them to convert the Light Cyan to Cyan and Light magenta to Magenta.
You'll still have your 1380 config and you'll get increased production speeds...
rom3o
C,M,Y,K,lc,Lm
OR
C,C,M,M,Y,K
one of the print heads (LC) suddenly stopped working for no reason. The repair is very expensive. That's why I want to get rid of these two colors.
Pauly
Printrade.com.au
You should have mentioned it from the beginning
The answer is yes, you can technically downgrade or upgrade the printer.
not 100% sure if the techs can do it as it's all apart of the firmware.
May or may not need to reconfigure the whole machine. i don't actually know the process. but all the machines are identical, just different configuration of printhead channels.
rom3o
I am just an operator and had no influence on the choice of machine. Thank you for your answer.
Pauly
Printrade.com.au
My advice to pass on to the decision maker:
Replace the print head. Turn it into a 2x cyan and 2x magenta machine. This configuration improves print quality in production modes & has faster production modes.
If you downgrade to a 1360, you now lose 2x print heads. 1 dead one, and one good one. Devalues the machine.
Good luck!
