S4LDesigner
Hi everyone,
We've been running the Mutoh's through FlexiSign Pro for years. While each ValueJet prints color slightly differently (even when using the same profiles), they handle color pretty consistently.
We have recently added a Roland and would prefer to continue printing and cutting everything through Flexi/Production Manager, rather than having to set up some jobs for Flexi and Some for VersaWorks. It's a time management/workflow issue.
My problem: the colors just don't match. Not even close. Example: Customer X's logo has been printing in the same blues and reds for 6 years on the ValueJets. If I try to reprint an existing file on the Roland, I can tweak the blues to be close by adjusting the Ink Limits and the Output Channels, but then the red is a horrific brown. I could change the CMYK composition of the red in the FS file, but then I'd have to change it back to print on the Valuejet. Not an optimal solution.
I cannot locate Roland ICC profiles for Flexi. I have tried to adjust the Ink Limits and the Output Channels on the Roland in Production Manager to no avail. If I get one color perfect, another goes awry.
We need all of the printers to be interchangeable for any new job or reprint. We just don't have time to do color tests and adjustments every time we switch printers.
Has anyone run into this problem? If so, how did you fix it?
We love Flexi, but is there another Design & RIP program out there that could better synchronize these printers from different manufacturers?
Desperately seeking solutions, and appreciate any suggestions.
Thank you.
Thank you.
