Jim Hill
When installing new cap tops does it matter which way the cap top is installed.
On one side you have a short piece of plastic does it matter which side this is on when you install the cap top?
My printer is an SP-300 with two heads. Does it matter if the yellow is on the right side with the magenta on the left? Or do I have it backwards.
I can order new cap tops but the ones in there now are only two weeks old.
Can they go bad that quick?
When you replace cap tops do you also replace the two springs under
them?
The printer was working perfectly and the only thing I can think of is it has been sitting for three days without any use before this problem started.
Thanks for your advice. Jim
them?
