Plotter-FIX
Hello everyone,
I'm David, a technician from Germany. I'm currently facing a challenge with a Mimaki JV150 printer that I hope someone here might be able to help with.
Here's the situation:
Questions:
Best wishes, David
- The printer was originally set up with an 8-color CMYK configuration.
- I flushed all the lines manually using a syringe with solvent followed by air, then water-based cleaner, followed by air.
- Performed a head wash using the old print head, then replaced the damper and installed a new print head.
Questions:
- How can I activate or add SB54 as a selectable ink type in the printer settings? Are there specific parameters I need to adjust to enable this option?
- Once I manage to select SB54, how can I inform the system that the printer is already filled with ink, considering I'm using only 4 cartridges?
Best wishes, David
