Cleaning makes things worse?
daenterpri
Why would cleaning make missing nozzles worse? This last week, if say I have a couple nozzles missing, I'll do a clean(power or standard), and it will make it way worse! I'll go from a couple to half of the nozzles missing on some colors. It's very frustrating. Basically, to get full nozzles again, I have to draw the ink through the heads with a syringe. Why should I have to do that? What causes cleaning to not work?
daenterpri
When you say, "Faulty cap top", do you mean the rubber seals on top of the capping station?
Would that involve me purchasing a brand new capping station?
randya
Could be that the seals are sealing but the pump, tubing, vacuum breaker, drain are not working properly.
Same thing could occur is there is a leak in the ink delivery system.
Or if a cartidge is empty.
