Clogged Damper
jc1cell
Based on your experience, what should I look for in a clogged damper?
On the 1604 I run I can pull ink easily on the black damper. The head is clogged, I'm just trying to eliminate factors that caused it to go from full nozzle test to an array of dispersed lines.
The cleaning pulls ink great (except the black of course). Placing the head in a container with flush, all nozzles pull and push fluid quite well except the black.
I'm still working on that aspect of the issue but would like to eliminate all possible causes for the head to clog that way before passing out judgment.
Thanks,
jc
jc1cell
Will do. Just wanted to get insight on any specific things to look for in a damaged damper as part of troubleshooting.
thanks,
jc
