cmyk control panel mutohvj1614
randya
If I understand correctly, you want to print CMYK stripes on each panel, that would be in the RIP.
randya
I forget what it is called...gutters?
Should be in the same section of the RIP where you print info, I believe.
Arstron
In flexisign pro 8.1, I know that you have to go threw production manager, go to default job properties, then to Labels and Marks. Although I havnt tried it, Print color bands is what you are looking for I believe. I would test this out if I could.
henryp
In Onyx, select the printer, then click on change, a window will pop up, click on setup, another window will pop up, select Printing Gutter, either left, right or both. you can also specify the size you want.
