jimmmi
Hello, i have a question about Colorgate color replacement using Color Atlas. For spot colors for example, it has it ready in color replacement dialog, i double click change manually values on the right column in Lab sytem, to the values of the spot color and use color atlas to print swatches.(maybe there is an easier way but havent find it yet).
Then select the one i like and color is replaced.
The more complex is with cmyk
Lets say i have a PDF with letters in some CMYK color. The only way i found for using color atlas is tottaly manually and very complex. I double click to show the advanced view, use color picker and click on the color. It opens the color replacement dialog, i copy the exact values form left column to right column one by one and saveit. Then manually again i open color replacement dialog, make a new entry using previous cmyk values left, copy to the right column, use color atlas, and when i find which color i like i select it. So i have two entries now. I copy the values from second entry i created to the first i created with color picker and then the color is replaced. I think i am doing something wrong. Too many steps for something so simple like a cmyk color replacement but havent found any faster. Can someone describe the corect procedure?
