I was already yelling at the screen when I read 2080.I assume this is obvious.
I forget, does the 700 run a cooler curing unit, or is it about the same as the previous generation?
Yes, the Gen4 Latex printers use significantly lower heat signatures than all of the previous Latex printers. Most medias cure at temperatures lower than 195-degrees Fahrenheit on the 600/ 700/ 800 Series, (unless using a very low pass mode like 4-pass).I was already yelling at the screen when I read 2080.
"god rest his soul"?I think it was AndyD, god rest his soul, that was printing dark colors onto colored vinyl with a latex printer. I know you can print 3m 7725 24" white (this is the series with the clear synthetic liner), as I've done that before, but from what I recall, it made weeding a bit harder, as if heating the material caused the adhesive to slightly activate.
Printing black onto yellow sounds easy, the other way around you'd likely need a white ink under the yellow, unless you're after that 'ghost piss' effect. Have you considered just dropping black vinyl on top of yellow? From the cost of 3m, and amount required to sacrifice on a hp latex, I'd totally buy the two colors vs printing on one, at least if it was a one or two face job.
Right, kindly dead to the forum. Though I reckon I shouldn't joke."god rest his soul"?
i thought he had just left the forum.
My old man's right behind you, he peruses the obits like I used to the detention center bookings, except the entertainment value is... not the same.I just turned 70. It's that stage of life where every time you call an old friend there is a better than even chance they won't be above room temperature any more...
