Considering buying a Roland sol jet 2 sc-540 printer/cutter
White Designs
Hey guys, new to signs101. I've been cutting vinyl making decals for a little over 3 years now with some off brand plotter. Found a fairly cheap Roland sc40 and wondering what the pros and cons are to them really. Also the printer has been sitting for a couple years but am being told it worked awesome up until then. Owner says with a good servicing it should be up and running no problem. It seems to be in good shape. I just don't know enough about these to know if what I think is fairly cheap is actually a good deal and if I should go through with it. He's asking $2,100. What do you think?
And sorry if this isn't the place for this post. Thanks!
FrankW
Hands off. Dangerous.
If this printer is in proofed working condition, $ 1'200 is a good price (SC540 is at minimum 11 years old). But if not, it could take several tousand Dollars to bring it up and running again. 6 x DX4-Heads, each of them around $500 or more, 12 Dampers, 6 Cap Tops, 3 Pumps ... this printer have a big chance to be a real money pit, even if you can do the work yourself.
BigfishDM
Don't do it man, your asking for a nightmare! Those machines need to print all the time to keep the lines and heads in check.
lgroth
Bigfish is right... We have one, recently bought an XR640 and kept the old one for overflow and small jobs. Now that it's not being used daily it's a nightmare to keep it printing. An SC that has been idle for a while will probably need new heads...
niksagkram
If the owner says a good servicing will get it up and running, tell him/her to get it serviced before you even consider buying it! Then offer $1500.00 at the most. As FrankW said, it's not just heads to be concerned about.
Good luck.
Mark
