Hi
I'm absolutely new to the world of cutting. I'm used to send my work to a print and cut company (in illustrator) but lately it takes forever to get things cut with them, plus they upped the charge for cutting a lot. I've used this company for a pretty long time because they used to print and cut fast and for a reasonable charge. If I can cut my self I am also able to choose another printing company. Bonus!
I usually 'box' my designs with a 0.5pt border. This because I want to check if the dimensions I handed them are the same
My main question is this:
Can I have a company print a (as example) 8x8" design, that is boxed/bordered with a 10x10" 0.5pt line and manually set the position of the cutter to the corners of the box?
I mean, in illustrator, if my design is on a 10x10" art board, and I have a sport color cutting vector (design and box), can I import that as a cutting vector in Flexi?
Can I use the border + vector (10x10") that I would import into Flexi to manually set the 0.0 coordinate? Or do I need to specify print marks in Flexi too (and by that probably increasing the document dimensions). If I have to use the Flexi marks it would not be on the printed vinyl.
Oh man, this sounds complex, but I'm sure you know what I'm trying to do. I've read a few topics here but I'm not sure if I need to set crop marks in Flexi.
Any help would be very very much appreciated!
Thanks!
Thanks!
