Hey all,
I have a task that I perform in corel draw very frequently and I was wondering if there is a way to make a macro for it, I figured someone on here would know, or might be able to help.
That being said, I'm not familiar with how to make a macro.
Layer 1
Original cut contour lines
Layer 2
Bleed contours, .25" around the cuts These are all powerclipped artwork
Layer 3
Nested contours, copied from Layer 2
Process:
Pick one of the objects on Layer 3, taking note of the angle of rotation.
Find corresponding items on layers 1/2, select those two objects.
Change Layer 1/2 items angle of rotation to match that of the item from Layer 3. (I type this in by hand)
Shift+(select the item from Layer 3)
C - Center Horizontally
E - Center Vertically
Do this for all of the items
Is there a way to simplify all of this?
Layer 1
Layer 2
Layer 3
Process:
