Coreldraw X5 question - re: combining objects
Todd-sta
Stupid question for you - I work mostly in Illustrator, but trying to re-acclimate myself with Coreldraw.
I have an 'closed-path object' within a circle.... I surround them both and click on the 'combine' button. Generally this would make a 'cookie-cutter' object of the two, where the object in the center is now a 'voided' shape which you can 'see through.'
This didn't happen. Instead of combining like normal... both objects become solid... although in wireframe mode, it would appear that they are combined.... I cannot figure this out?!
I thought they might be on different layers or something...but heck, I can't even find the 'layers' dialogue.
Can you tell me why these two objects might not be combining normally?
I checked, and all 'nodes' are joined and both objects are closed-path objects.
Thanks.
bob
Try reversing the path on one of the objects before you try to combine them.
Todd-sta
Thanks for looking, but I have discovered the solution: Once I changed the 'direction' of the node rotation, then selected both objects again and 'combined' them... it worked and now displays correctly.
This is an oddity that just came back to me as I racked my brain thinking about what I did in the past when this happened.
Thanks - have a great weekend.
Todd-sta
Thanks Bob! I must have just been posting my discovery as you were posting your reply..... appreciate the help though!! Have a good one.
