crop mark cutting is way off
K2
I am using a Roland SP540V and when i use crop marks the cut is way off. If i just print and cut, its fine. It's only when i use the crop marks. i tried clibrating it on the machine and there seems to be no change, maybe i am doing it all wrong, any help would be appreciated.
Malkin
Does it go around and detect all 4 crop marks, in the right place?
Can you describe how the cuts are off?
njsigns
I had this problem - then I turned off the heaters on the machine, set the file to "use printer settings" in the heater controls dialog in versaworks, and let the machine cool to the touch before contour cutting. Loading the media straight helps too.
Gene
ZsVinylInc
I also have an SP-540V...Up until recently I had all kinds of cutting issues with Print / Lam / Cut or any cutting with crop marks. I recently re-calibrated the machine and found that if I do an environmental match in the morning before I start helps. Then I also use the printer settings for all the heat and cut. I also take the film out and let the machine cool for at least 15 mins longer if I can. Remember to turn the heaters off. reload the media and set it up for crop mark detection. I haven't had any problems since.
Sincerely,
Big Z
In Service Mode: Do a CROP ADJUST, then... do a Print Cut Adjustment. This will solve your issue. Also do an Env Match. If this doesn't help, clean your encoder strip Then do an Env Match
K2
Anyone know how to get into "Service Mode", I did the right, down, left power but it says service mode protected and wont let me in.
