SummitSignsandmore
I am experiencing an issue when I am trying to add a cut contour to some artwork.
When I apply the cut contour line in some areas the cut contour is not following the path like it should.
I have attached a close up image of one section that I am experiencing this.
It is happening inconsistently thru out the entire graphic. Any suggestions?
The thin gray (cut contour) line is a little tough to see but you can see that in some areas it doesn't follow the path it should
