CutContour not recognized in Onyx Poster shop
dasigndr
I AM EXPORTING MY cOREL dRAW x6 DESIGN TO A .PDF FILE, (WHICH i HAVE DONE FOR DECades) i THEN OPEN IT IN MY oNYX but Onyx is not recognizing my 100% Magenta CutContour line.
It shows as a magenta line in onyx but not as a cut line.
I have 2 other computers in my network and they work fine!
The only difference is these two other computers are Win 10 Home and my main computer is a Win 10 Pro.
I cannot see this being the problem.
HELP
White Haus
Not a Newbie
Check these settings under color tab when exporting to PDF:
Zoogee World
Domed Promotional Product Supplier
i would not think that would matter, but I did make it top layer and no didderence
I know in illustrator if it isn't the top layer it doesn't work, that is why I mentioned it. I don't use Onyx, but does it take eps files, as you could try saving it as a eps in Corel and see if you get a different result.
Zoogee World
Cutcontour doesn't needs its own layer......
No it doesn't, but needs to be at the top in the layer, at least for Illustrator and Versaworks to see it as a cut contour. I don't use Onyx, but was throwing out similar issues I've had to see if it might help.
dasigndr
tried .eps as well and no difference. I used to export all my print files as .eps files but our ONYX tech said it is better if it is a .pdf because .pdf and .tif keep all the meta data attached to the file and it is a better format for printing.. Just saying!
White Haus
Not a Newbie
I have checked and double checked all these. See pdf file attached showing all tabs when exporting.
Am I missing something?
Looks like your color tab is correct. That's really strange. So it's isolated to that one computer - was anything changed recently?
If you'd like to email me a file that's not working I can having a look. pat@signcraftdisplay.com
Edited to add: Is it just this one file? Or any file from that computer?
White Haus
Not a Newbie
Here you go. Whatever swatch you were using wasn't being recognized as spot color.
  • 16X8-North Star decal-rev1_Fixed.pdf
dasigndr
well!!! this file you sent is working properly when I open it in ONYX. Thanks a whole bunch...but, now tell me what I am doing wrong!
I set up my SPOT colour CutContour swatch the same way I did in both other computers. Please re-explain how I go about setting up my cut contour swatch please!!
White Haus
Not a Newbie
You're welcome. Glad it worked.
I've never had much luck creating custom spot color swatches in Corel, I've always installed Roland/Summa etc. swatches.
I tried uploading the swatch file here but it won't work, I'll email it to you now.
dasigndr
the file you sent me works!! Thank you a whole bunch. I have attached the file here if anyone else ever needs it.
